MQTT sensor, how to use with attributes?
It’s value_json not value.json
If the payload looks like this:
  "ZbReceived": {
    "Computer_Air_Quality": {
      "Device": "0x545C",
      "Name": "Computer_Air_Quality",
      "EF00/0212": 243,
      "Endpoint": 1,
      "LinkQuality": 107
then to reference the value of EF00/0212 you would use this:
value_json.ZbReceived.Computer_Air_Quality['EF00/0212']
The strange fact is that the attribute is showed even without extracting the json. If I add this, it will show exactly what is supposed to " { “string_state”: “test” } But instead of the “test”, seems hard to do some conditions…
Then there’s a fundamental problem here.
The example I had posted earlier in the thread is biased on a working example I posted 2 years ago:
Perhaps something has changed in how MQTT Sensor processes its json_attributes_template option.
Last test:
    json_attributes_template: >
      { "string_state": {{ 'on' if true else 'off' }} }
I know that post and I was hoping that you will answer to this post as well :smiley:
I will do the test now, just a sec
Edit: Not showing the attribute
Edit2: WAIT :smiley: I have a result
Edit3:
With this
      { "string_state": "{{ 'on' if true else 'off' }}" }
I see the attribute with state “on”. So… I needed to add some double quotas around the {{ }}
Look in Logs for any error/warning messages related to this MQTT Sensor.
I have a result here as well, I just added those double quotas, seems to work…
Still… the set stat still not working…
Where did you add double quotes? What you posted looks identical to what I had suggested.
This is what you gave me as code
And this is where I added
Strange again… take a look
This is the result of:
      { "string_state": "{{ value_json.ZbReceived.Computer_Air_Quality['EF00/0212'] }}" }
And this:
is the result of:
      { "string_state": "{{ 'on' if value_json.ZbReceived.Computer_Air_Quality['EF00/0212'] < 1000 }}" }
And it is going through all the details (temperature, humidity and so on…)
You’re trying to confuse me, right? :slightly_smiling_face:
The single-line template you just posted isn’t the multi-line template you had posted in the message where you first said you added double-quotes.
OK, understood. The result of the template isn’t automatically interpreted to be a string so, to create a valid JSON string value, we must explicitly wrap the template’s result in double-quotes.
Based on that information, try the original suggestion with the addition of double-quotes.
      { "string_state":
        "{{ 'very low' if this.state | float(0) <= 13 else
            'low' if 15 <= this.state | float(0) <= 18 else
            'normal' if 20 <= this.state | float(0) <= 25 else
            'high' if 27 <= this.state | float(0) <= 30 else
            'very high' if this.state | float(0) >= 32 else
            this.attributes.string_state | default('unknown') }}" }
It is working :partying_face: :partying_face:
But still, how this “this.state” knows that it is about the state of ['EF00/0212'] ?
Edit: I am stupid, don’t mind me :))) I understood now
Whew! Glad to hear it’s working now because I was running out of ideas. :slightly_smiling_face:
I can’t thank you enough.
I am now trying to understand how to modify this, in order to have the same last result after the HA restarts. Because if I restart HA, for just a second, the state of the sensor will be unknown, then the value it will be shown… and so on… :slight_smile:
Is the device that publishes this payload:
  "ZbReceived": {
      "Device": "0x545C",
      "EF00/0212": 243,
      "Endpoint": 1,
      "LinkQuality": 107
publishing it as a retained message?
Oh ok, I think that this should be done from Tasmota, per device.
I wanted to ask you… what this " | default(‘unknown’)" is doing? I dont understand, can you please explain to me?
If this.attributes.string_state doesn’t exist then the default filter reports unknown.
Thank you. I can sleep well tonight :smiley:
Hi again @123
I have a small issue on the same subject… maybe you know what is happening.
I have this sensor which you helped me with:
  - name: Bedroom Minibar Ambient Battery
    state_topic: "tele/ZigBee_Bridge/0253/SENSOR"
    unit_of_measurement: "%"
    device_class: battery
    value_template: >
      {% if is_number(value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0)) %}
      {{ value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0) }}
      {% else %}
      {{ states('sensor.bedroom_minibar_ambient_battery') }}
      {% endif %}
    json_attributes_topic: tele/ZigBee_Bridge/0253/SENSOR
      { "string_state":
        "{{ 'low' if this.state | float(0) <= 30 else
            'normal' if this.state | float(0) > 30 else
The problem is that the attribute will only change it’s state if the sensor state changes the second time… So, if I will receive a lower value than 30, the attribute state will change only if the sensor will receive another lower value… Same for higher than 30… I don’t understand why is like this…
Any idea?
Thank you in advance!
