- name: Bedroom Minibar Ambient Battery
state_topic: "tele/ZigBee_Bridge/0253/SENSOR"
unit_of_measurement: "%"
device_class: battery
value_template: >
{% if is_number(value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0)) %}
{{ value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0) }}
{% else %}
{{ states('sensor.bedroom_minibar_ambient_battery') }}
{% endif %}
json_attributes_topic: tele/ZigBee_Bridge/0253/SENSOR
json_attributes_template: >
{% set t = value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0) %}
{% else %}
{% set t = states('sensor.bedroom_minibar_ambient_battery') %}
{% endif %}
{ "string_state":
"{{ 'low' if t <= 30 else
'normal' if t > 30 else
this.attributes.string_state | default('unknown') }}" }
This is what it shows
Edit: I think it is working, but it should first receive a value, than the state will show up
Thanks!
I didn’t change anything in value_template
. It’s probably reporting unknown
because it hasn’t received a payload yet.
Exactly!
And, can I do something to show a value if no payload received yet? Maybe show the last known value?
Edit: I have solved it by making the device publish the value sensor as retained. It is a good solution or I can do something from this code?
The MQTT Sensor’s value_template
is processed only when a payload is received.
I still got some issues, because if I would receive a different sensor’s value from the same device, the BatteryPercentage would act like it had no payload… so i did this to solve it:
value_template: >
{% if value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] %}
{% set var = value_json['ZbReceived']['Bedroom_Minibar_TempHum_Sensor']['BatteryPercentage'] | float | round(0) %}
{% else %}
{% set var = states('sensor.bedroom_minibar_ambient_battery') %}
{% endif %}
{{ var }}
{% endif %}
{% else %}
{% endif %}
{ "string_state":
"{{ 'low' if var <= 30 else
'normal' if var > 30 else
{% else %}
{ "string_state": "{{this.attributes.string_state}}" }
{% endif %}
Kinda a big code for just a sensor Do you know any other solution, with a smaller code? I want to optimize how the code looks and make it smaller
If the state_topic can receive payloads meant for more than one sensor, you should consider implementing Strategy #2 described in the following topic:
