How do I create a custom mqtt sensor where the json attribute I want is not always present?
mqtt:
- name: "Valve3 Position"
state_topic: "tele/esp32-dev-05/+"
value_template: >
{% set pos = (value_json.Valve.Position | int | bitwise_and(3) ) %}
{{ ["X", "H", "W", "H+W"][pos] }}
This works, but it throws an error for messages which don’t include Valve
A good message looks like this {"Time":"2024-03-10T18:05:37","Valve":{"Position": 1}}
I guess I need to test for the presence of Valve
, but I can’t see how to do that.
Another approach could be to tighten the topic, but I want to catch both tele/esp32-dev-05/RESULT
and tele/esp32-dev-05/SENSOR
. The problem with +
is that I also catch tele/esp32-dev-05/STATE
, and that does not include Valve
As you can see, this is Tasmota. I have created a custom sensor because the default Tasmota sensor only updates in HA on tele/node/SENSOR messages, which is every 5 mins by default. I want it to update on change, which means I need to catch the tele/+/RESULT message.
Many thanks to anyone who can help.
