Hi All,
I am having a bit of trouble getting a value_template to work correctly. I have a JSON coming through an MQTT with a list of sensors (13 total) and need to parse the value of each to individual sensors. I can parse the value in the template tool using {{ value_json.System.Slot[0].Module.Sensor.Value }}
, but cant get it to work in a sensor.
Here is the full json;
"System" : {
"Slot" : [ {
"ID" : "1",
"Module" : {
"ID" : "05",
"Name" : "SL1",
"CustomName" : { },
"Sensor" : {
"Name" : "Temp",
"CustomName" : { },
"Value" : "76.9",
"Units" : "F"
"ID" : "2",
"Module" : {
"ID" : "05",
"Name" : "SL1",
"CustomName" : { },
"Sensor" : {
"Name" : "pH",
"CustomName" : { },
"Value" : "8.10",
"Units" : { }
"ID" : "3",
"Module" : {
"ID" : "05",
"Name" : "SL1",
"CustomName" : { },
"Sensor" : {
"Name" : "ORP",
"CustomName" : { },
"Value" : "442",
"Units" : "mV"
"ID" : "4",
"Module" : {
"ID" : "03",
"Name" : "SL2",
"CustomName" : { },
"Sensor" : {
"Name" : "Temp",
"CustomName" : { },
"Value" : "77.4",
"Units" : "F"
"ID" : "5",
"Module" : {
"ID" : "03",
"Name" : "SL2",
"CustomName" : { },
"Sensor" : {
"Name" : "pH",
"CustomName" : { },
"Value" : "8.31",
"Units" : { }
"ID" : "6",
"Module" : {
"ID" : "03",
"Name" : "SL2",
"CustomName" : { },
"Sensor" : {
"Name" : "Salinity",
"CustomName" : { },
"Value" : "Error",
"Units" : "ppt"
"ID" : "7",
"Module" : {
"ID" : "07",
"Name" : "PC4",
"CustomName" : "Sump-D",
"Sensor" : {
"Name" : "CH1",
"CustomName" : "MainPump",
"Value" : "ON",
"Units" : { }
"ID" : "8",
"Module" : {
"ID" : "01",
"Name" : "PC4",
"CustomName" : "Sump-B",
"Sensor" : {
"Name" : "CH2",
"CustomName" : "Skimmer1",
"Value" : "ON",
"Units" : { }
"ID" : "9",
"Module" : {
"ID" : "01",
"Name" : "PC4",
"Sensor" : {
"Name" : "CH3",
"CustomName" : "Skimmer2",
"Value" : "ON",
"Units" : { }
"ID" : "10",
"Module" : {
"ID" : "01",
"Name" : "PC4",
"Sensor" : {
"Name" : "CH1",
"CustomName" : "WM-B",
"Value" : "ON",
"Units" : { }
"ID" : "11",
"Module" : {
"ID" : "07",
"Name" : "PC4",
"Sensor" : {
"Name" : "CH2",
"CustomName" : "WM-C",
"Value" : "ON",
"Units" : { }
"ID" : "12",
"Module" : {
"ID" : "06",
"Name" : "PC4",
"CustomName" : "LED 2",
"Sensor" : {
"Name" : "Amps",
"CustomName" : { },
"Value" : "1.0",
"Units" : "A"
"ID" : "13",
"Module" : {
"ID" : "02",
"Name" : "PC4",
"CustomName" : "LED 1",
"Sensor" : {
"Name" : "Amps",
"CustomName" : { },
"Value" : "2.0",
"Units" : "A"
Appreciate the help
Cody-
