Hi all,
I am using mqtt discovery, sending config data from ESP12e to hassio.
Home Assistant OS 5.9 running on Raspi 4 model B.
config_topic: homeassistant/sensor/wts_dist/config
state_topic: homeassistant/sensor/wts_dist/state
When subscribed with # topic in Configuration>>Integration>>Mqtt_broker>>Configure>>Subscribe, I am getting json data on config_topic as follows:
“name”: “Water_Tank_Sensor_D”,
“dev_cla”: “None”,
“stat_t”: “homeassistant/sensor/wts_dist/state”,
“avty_t”: “homeassistant/sensor/wts_dist/available”,
“pl_avail”: “online”,
“pl_not_avail”: “offline”,
“unit_of_meas”: “%”,
“val_tpl”: “{{ value_json.filledcap}}”,
“ic”: “mdi:water-pump”,
“uniq_id”: “Water_Tank_Sensor_D-2C_3A_11_11_11_11”,
“dev”: {“ids”: [“Water_Tank_Sensor_D-2C_3A_11_11_11_11”],“name”: “Water_Tank_Sensor_D”,“mdl”: “NodeMCU 1.0 (ESP12E module)”,“mf”: “Amica”,“sw”: “v0.1”}
But, the device is not getting added to core.device_registry & core.entity_registry.
mqtt_discovery is set to true, confirmed in core.config_entries. Earlier it was working perfectly, has anything changed with new hass os version 5.9?
Can any one help me on this?
Thanks in advance
