Im completely new to HA but it seems all really cool. I have started a project with a Arduino Nano IoT with a temp and Hum sensor. I send these values by MQTT to HA. It al works if I use Node Red but I would like to use Lovelace cards. So I tried to find good info on this forum, nevertheless I can’t get it working.
As far as I understand I need to adjust the yaml config file, this is what I have done.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
- platform: mqtt
name: "Frog tank temperature"
state_topic: "FrogTank/Temperature"
unit_of_measurement: "°C"
value_template: "{{ value_json.temperature }}"
No when I use a Gauge card and write as entity:
sensor.Frog_tank_temperature
It states that the entity is not available. I have restarted the broker (which runs on an RPI) allready. But I assume that the issue has to do with the config file or so This shouldn’t be so hard anymore. If it works on Node Red I should be able to get it work on Lovelace a well…I guess.
Could anybody point out to me what I may be doing wrong?
