MQTT Sensor options property
Hi All,
I’d like to ask for your help.
I have an MQTT Sensor which gets some Air Quality information from a Thermostat as a text (Bad, Good, Excellent).
mqtt:
      - name: "Thermostat Air Quality"
        state_topic: "homeassistant/thermostat/air_quality/cmd"
        qos: 2
I’d like to have something similar like in this PR by @frenck (be able to set the possible options in the YAML file so as I’m creating automations, I would be able to select From and To states from a list and avoid making trouble with a typo).
What do you think, would this be possible?
Thanks in advance!
Maybe this will help. Not sure
  - platform: mqtt
    qos: 2
    value_template: >
      {% set options = ["Bad", "Good", "Excellent"] %}
      {% if value in options %}
        {{ value }}
      {% else %}
        Unknown
      {% endif %}
    json_attributes_topic: "homeassistant/thermostat/air_quality/cmd"
    json_attributes_template: >
      {% if value_json.state in options %}
          "state": "{{ value_json.state }}"
      {% else %}
          "state": "Unknown"
      {% endif %}
Hi @MrJelly17 ,
Many thanks for your answer. Unfortunately the options do not pop up in the editor.
