Hey folks,
after a long time I try to get back to hass (thanks corona11). What I do get in the config validation after a bunch of updates is:
Invalid config for [sensor.mqtt]: [payload_on] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->payload_on. (See ?, line ?).
Invalid config for [sensor.mqtt]: [json_attributes] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->json_attributes. (See ?, line ?).
Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 74).
**Can you tell me why the validation aren’t finding the right lines? (“See ?, line ?”) **
Could you tell me whats now wrong with the “payload”?
I do have two lines with payload in my conf:
#XCube_binary_sensor_d:
- platform: “mqtt”
state_topic: “zigbee2mqtt/Xiaomi_Cube”
availability_topic: “zigbee2mqtt/bridge/state”
value_template: “{{ value_json.contact }}”
payload_on: false
payload_off: true
device_class: “door”
and
###BW SHP13
switch:
- platform: "mqtt"
state_topic: "zigbee2mqtt/Blitzwolf_SHP13"
availability_topic: "zigbee2mqtt/bridge/state"
**payload_off: "OFF"**
**payload_on: "ON"**
value_template: "{{ value_json.state }}"
command_topic: "zigbee2mqtt/Blitzwolf_SHP13/set"
I use the Zibee CC2531 to MQTT bridge.
Thanks.
