I have a ESP32 Solar sensor which is sending data to my MQTT Mosquitto Server. In the middle of the night, as soon as the battery is empty, the sensor goes offline. When it comes back, the history graph in Home Assistant starts with the old value which creates this vertical line which you can see on the picture. I want to get rid of the old/previous value and the vertical line.
So far I couldn’t figure out how to achieve that. Any idea or advise if highly appreciated.
Here is my MQTT Sensor config:
- name: "Deposito %"
state_topic: esp32-00001-01/sensor/deposito_/state
icon: mdi:water-check-outline
unit_of_measurement: "%"
availability_topic: esp32-00001-01/status
This is the corresponding config in ESPHome:
- platform: ads1115
setup_priority: -100.0
multiplexer: 'A3_GND'
gain: 4.096
retain: false
accuracy_decimals: 0
update_interval: 10s
filters:
- filter_out: 0.00
- clamp:
min_value: 0.02
max_value: 3.6
ignore_out_of_range: true
- skip_initial: 5
- sliding_window_moving_average:
window_size: 20 #creates a moving average of the last 10 values
send_every: 10 #sends the moving average at every measurement
send_first_at: 10 #
- delta: 0.02
- calibrate_linear:
- 0.02 -> 0.0
- 3.56 -> 100.0
Thank you.
