Hello-
I’ve recently moved from a Raspbian HASS install to Hassbian 0.91.0 and am basically rebuilding from scratch. I am getting an ‘unknown state’ in UI and on http://:8123/dev-state.
I don’t see any MQTT related errors in the log. The multisensor (Bruh, NodeMCU based) outputs fine to serial in Arduino IDE; it is connecting to homeassistant. I suspected that there was some sort of conflict between my manually set up MQTT server in configuration.yaml and the one on the integration page. I’ve tried to delete UI config, then the .yaml mqtt config to no avail (I think UI config overrides .yaml config). I’ve tried commenting out the name in the sensor entity configuration as I saw that it caused an unknown state in hass.io back in January.
Any Ideas what might be the cause of this ‘unknown state’?
relevant configuration.yaml:
#SENSOR NODE 1
- platform: mqtt
state_topic: "revel/sensornode1"
name: "SN1 Humidity"
unit_of_measurement: "%"
value_template: '{{ value_json.humidity | round(1) }}'
# - platform: mqtt
# state_topic: "revel/sensornode1"
# name: "SN1 LDR"
# ##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
# unit_of_measurement: "LUX"
# value_template: '{{ value_json.ldr }}'
# - platform: mqtt
# name: "SN1 PIR"
# value_template: '{{ value_json.motion }}'
- platform: mqtt
name: "SN1 Temperature"
unit_of_measurement: "°F"
value_template: '{{ value_json.temperature | round(1) }}'
relevant groups.yaml:
master_bedroom:
entities:
# - light.master_bedroom_lights
- light.master_bedroom_ceiling
- light.master_bedroom_bath
- switch.master_bedroom_outdoor_lights
- sensor.sn1_humidity
- sensor.sn1_temperature
Any suggestions much appreciated
*minor edits for typos / brevity
-R
