MQTT sensor Temperature GPU
Hello everybody,
I have a problem with mqtt sensor and the temperature of GPU from my Pi.
First, I’m running Home Assistant 0.190.4 with docker on a Raspberry Pi3B+. Mosquitto is installed on this Pi and I have a script for publish the temperature of the GPU on a topic.
When I listen to the topic from the developer tools MQTT, I can see the value (temp=50.1’C for example)
In my configuration.yaml, I declare a mqtt sensor with a value_template like this
'{{ value | replace("temp=", "") | replace("''C", "") }}'
but the value show permanently unknown.
Anybody for any ideas?
It would help if we knew what you receive on that topic. You do a lot of replace, but we don’t know the original.
The value that I receive is like
temp=58.1'C
This is the result of the command
/opt/vc/bin/vcgencmd measure_temp
Do you have the mqtt topic correct?
Can we see your full sensor config?
Yes the topic is correct, it’s work when I listen to the topic from the mqtt developers tools
Here is my complete config for this sensor
  - platform: mqtt
    state_topic: raspberry/temperature/GPU
    unit_of_measurement: "°C"
    value_template: '{{ value | replace("temp=", "") | replace("''C", "") }}'
Capture
Your state topic is incorrect.
This:
is not the same as this:
state_topic: raspberry/temperature/gpu
Capitalisation is important.
This is the solution.
Tank you!
