I want to be able to write to Logbook all events from a custom MQTT sensor called sensor.asterisk_call_status
By default it doesn’t write anything, so I tried it manually as you can see bellow, but it doesn’t write it to that specific sensor. If I look at the logbook, I can see the record, but it I can’t click on it and it’s not associated with my sensor.
service: logbook.log
message: 2test
Is there another alternative on how to get the events on my logbook?
Edit: I don’t know if it helps, but you can find my project here which is a service that sends events on MQTT server.
