Hi I recreated the bed sensor project from Everything Smart Home and it works grate but every time when I am restarting Home Assistant the sensor gets unavailable, and I have to restart the sensor.
I use the Mosquitto broker without any changes, and the code that is running on the ESP is this:
#include <Arduino.h>
#include <HX711.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include "config.h"
HX711 scale; // Initiate HX711 library
WiFiClient wifiClient; // Initiate WiFi library
PubSubClient client(wifiClient); // Initiate PubSubClient library
void setup() {
Serial.begin(74880);
Serial.println();
WiFi.mode(WIFI_STA);
WiFi.begin(SSID, PASSWORD);
Serial.print("Connecting...");
while (WiFi.status() != WL_CONNECTED) { // Wait till Wifi connected
delay(500);
Serial.print(".");
Serial.println();
Serial.print("Connected, IP address: ");
Serial.println(WiFi.localIP()); // Print IP address
client.setServer(MQTT_SERVER, 1883); // Set MQTT server and port number
client.setCallback(callback); // Set callback address, this is used for remote tare
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN); // Start scale on specified pins
scale.wait_ready(); //Ensure scale is ready, this is a blocking function
scale.set_scale();
Serial.println("Scale Set");
scale.wait_ready();
scale.tare(); // Tare scale on startup
scale.wait_ready();
Serial.println("Scale Zeroed");
void loop() {
float reading; // Float for reading
float raw; // Float for raw value which can be useful
scale.wait_ready(); // Wait till scale is ready, this is blocking if your hardware is not connected properly.
scale.set_scale(calibration_factor); // Sets the calibration factor.
// Ensure we are still connected to MQTT Topics
if (!client.connected()) {
reconnect();
Serial.print("Reading: "); // Prints weight readings in .2 decimal kg units.
scale.wait_ready();
reading = scale.get_units(10); //Read scale in g/Kg
raw = scale.read_average(5); //Read raw value from scale too
Serial.print(reading, 2);
Serial.println(" kg");
Serial.print("Raw: ");
Serial.println(raw);
Serial.print("Calibration factor: "); // Prints calibration factor.
Serial.println(calibration_factor);
if (reading < 0) {
reading = 0.00; //Sets reading to 0 if it is a negative value, sometimes loadcells will drift into slightly negative values
String value_str = String(reading);
String value_raw_str = String(raw);
client.publish(STATE_TOPIC, (char *)value_str.c_str()); // Publish weight to the STATE topic
client.publish(STATE_RAW_TOPIC, (char *)value_raw_str.c_str()); // Publish raw value to the RAW topic
client.loop(); // MQTT task loop
scale.power_down(); // Puts the scale to sleep mode for 3 seconds. I had issues getting readings if I did not do this
delay(3000);
scale.power_up();
void reconnect() {
while (!client.connected()) { // Loop until connected to MQTT server
Serial.print("Attempting MQTT connection...");
if (client.connect(HOSTNAME, mqtt_username, mqtt_password)) { //Connect to MQTT server
Serial.println("connected");
client.publish(AVAILABILITY_TOPIC, "online"); // Once connected, publish online to the availability topic
client.subscribe(TARE_TOPIC); //Subscribe to tare topic for remote tare
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000); // Will attempt connection again in 5 seconds
void callback(char* topic, byte* payload, unsigned int length) {
if (strcmp(topic, TARE_TOPIC) == 0) {
Serial.println("starting tare...");
scale.wait_ready();
scale.set_scale();
scale.tare(); //Reset scale to zero
Serial.println("Scale reset to zero");
The config.h contains this:
// Wifi Settings
#define SSID "my_ssid"
#define PASSWORD "my_password"
// MQTT Settings
#define HOSTNAME "bed-sensor"
#define MQTT_SERVER "my_MQTT_SERVER"
#define STATE_TOPIC "home/bedroom/bed"
#define STATE_RAW_TOPIC "home/bedroom/bed/raw"
#define AVAILABILITY_TOPIC "home/bedroom/bed/available"
#define TARE_TOPIC "home/bedroom/bed/tare"
#define mqtt_username "my_mqtt_username"
#define mqtt_password "my_mqtt_password"
// HX711 Pins
const int LOADCELL_DOUT_PIN = 2; // Remember these are ESP GPIO pins, they are not the physical pins on the board.
const int LOADCELL_SCK_PIN = 3;
int calibration_factor = 20676; // Defines calibration factor we'll use for calibrating.
The sensor is outputting the weight and the raw sensor data and is integrated with these lines
- platform: mqtt
icon: mdi:weight
state_topic: "home/bedroom/bed"
unit_of_measurement: "kg"
availability_topic: "home/bedroom/bed/available"
- platform: mqtt
state_topic: "home/bedroom/bed/raw"
unit_of_measurement: "raw"
I hope someone can help me.
