Mqtt sensor ... unknow
after searching and testing solutions from the forum, I’m still unable to get mqtt value … it is “unknown”
Thanks for your help and suggestions.
What I have :
  • a sensor sending json --> {“orp”:" 100"} under the topic /piscine/sondes
  • Mosquito + mqtt.fx : I can get the payload
  • HA : when using ‘listen to topic’ in the mqtt integration, I can get the payload
  • HA : when I publish to the topix, mqtt.fx get the payload
  • HA : mqtt_dump.txt contains the payloads
the configuration.yaml I’m using :
sensor :
  - platform: mqtt
    unique_id : sondeORP
    state_topic: “/piscine/sondes”
    qos : 0
    value_template: "{{ value_json.orp }}"
    icon: mdi:information-outline
I’ve tested with direct value (no json), with quoted/unquoted value (10 or “10”) … same result : “unknown”
I’m sure I’m missing something, but what ?
:slight_smile:
Use regular quotes (") instead of the fancy onces you have now.
@Francis
Working …
It happens when you copy/paste as a dummy
Thanks, I’ll try to watch for my typos, next time
:slight_smile:
