MQTT sensor Unknown
Hi guys, I’d really appreciate some help
I’ve installed Mosquito (hass.io, 0.90.2), I’m trying to set up an MQTT sensor which I will publish to using my own attributes, in this case for testing purposes the only attribute is x (if this works i’d like multiple, though unsure of how the syntax for value_template for multiple attributes)
this is in my configuration file
  - platform: mqtt
    state_topic: "home/plants/1"
    value_template: "{{ value_json.x }}"
    json_attributes_topic: "home/plants/1/attributes"
this is the JSON I’m sending (tried to send to both topics)
“x”:908
in the frontend/dev-info etc… I can see the sensor “Test”, the value is “Unknown” and it has no attribute x or anything else for that matter.
also in the integration page under mosquito there is no sensor x or sensor test.x
any idea what im doing wrong?
thanks
Try and change this:
“x”:908
to this:
"x":"908"
and see if that works better
holy crap that actually worked… I wasted hours on that crap haha…
but doesnt that mean my value is a string now and not an integer? not ideal but I can probably live with that.
I tried updating that attribute a few times, hass does not seem to keep the history of these values, is that a limitation of the mqtt sensor? the history is critical for me, if not I will need to find another way then
Just drop the double-quotes delimiting the value.
{ "x": 908 }
The original issue was you weren’t using plain double-quotes (") but fancy double-quotes (). JSON requires plain double, or single, quotes for delimiting strings.
It records a history of an entity’s states, not attributes.
