MQTT sensors from domoticz, only first one works, why?
Hello to all, I’m new to ha.
I’m trying to import some mqtt values inside domoticz, and I’m using this config:
  - platform: mqtt
    unique_id: “Autoconsumo”
    state_topic: "domoticz/in"
    unit_of_measurement: 'kWh'
    force_update: false
    value_template: "{% if value_json.idx == 5 %} {{ value_json.svalue }} {% endif %}"
    device_class: energy
    state_class: measurement
  - platform: mqtt
    unique_id: “Sunnyboy”
    force_update: false
    value_template: "{% if value_json.idx == 95 %} {{ value_json.svalue }} {% endif %}"
  - platform: mqtt
    unique_id: “Consumo Total”
    force_update: false
    value_template: "{% if value_json.idx == 92 %} {{ value_json.svalue }} {% endif %}"
The trouble is that only that first sensor works properly, the other ones shows zero. Why?
What is the value of “value_json.idx”?
If it isn’t either 95 or 92 then those sensors values should be unknown. I’m surprised it’s 0.
Fixed, the trouble was the format, I had to use like this:
  - platform: mqtt
    state_topic: "homeassistant/autoconsumo"
    unit_of_measurement: 'Wh'
    force_update: false
    value_template: "{{ value_json }}"
    last_reset_topic: "homeassistant/autoconsumo"
    last_reset_value_template: entity_id
  -   platform: mqtt
      state_topic: "homeassistant/sunnyboy"
      force_update: false
      last_reset_topic: "homeassistant/sunnyboy"
FYI that format is the old style.
Old:
    -  platform: mqtt
New:
mqtt:
       -  name: sunny
           state_topic: etc etc
       -  name: nextentry
