Mqtt server help
Trying to add my MQTT broker to a bluetooth tracker thingy for ESPHome
my code looks like this:
broker: 192.168.xx.xx:1883
username: “mqtt-user”
password: “asdasdasdasdasdasdas”
But i keep getting the error
[mqtt:204]
Couldn’t resolve IP address for ‘192.168.xx.xx:1883’!
How can i fix this? What am i doing wrong? The IP address i’m using is the IP address of my raspberrypi on my internal network
Try the IP Address without the port. If I remember correctly, I tried your way first also and it didn’t work either.
EDIT: I am not sure what you would do if your MQTT Broker used a different port.
Agree about just add the IPv4 without the IP port.
Use a MQTT tool like https://mqtt-explorer.com/ to check what IPv4 and credentials connect to Mosquitto. Notice the IPv4 is separate from the port:
#include <usual advice>
Here’s a wakthrough with a direct link to the HASS MQTT settings to define a local user:
Any more insight will need logs…
If this helps, :heart: this post!
thanks guys, is my syntax correct?
it wasnt, it is now.
its working! thanks
For anyone who reads this I needed the IP address on its own, without the port but in inverted commas.
I used the tool to check the ip address so both posts were incredibly helpful.
