Hi Guys trying to add a MQTT broker to HA with the following code but when launching HA/services mqtt publish option is not avialable
mqtt
broker: 192.168.2.1
port: 1883
client_id: home-assistant
username: username
password: xxxx
keepalive: 60
protocol: 3.1.1
any one help
mqtt must end with a colon.
Here’s mine
mqtt:
broker: 127.0.0.1
port: 1883
client_id: home-assistant-1
keepalive: 60
protocol: 3.1
# username: USERNAME
# password: PASSWORD
Edit: and please read the blue box on top of every page here. ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Hello
Thank you for the help but it still does not work.
mqtt:
broker: 192.168.2.1
port: 1883
keepalive: 60
protocol: 3.1
username: username
password: password
when HA starts it list mqtt as invalid config
On wich OS runs your HA?
MQTT broker installed and running?
Edit: Aaahh, your indentation is not correct. There should be two spaces in front.
mqtt:
broker: ...
I changed it to two spaces makes no difference.
I have a linux device running mosquito and is subscribed to a topic. HA is installed on windows 10 and they connect via Ethernet cable .
Strange! Firewall on WIndows 10?
Anything in the logs of mosquitto?
Here’s a mosquitto.conf that Hassbian uses https://github.com/home-assistant/hassbian-scripts/blob/master/files/mosquitto.conf
Then i give up for now!
Btw, if you have a Linux device, why not running HA on it?
Im not sure if i can. the linux device is a multitech lora gateway. dont want to mess with its other duties
gpbenton
(Graham)
8
The config looks fine to me also. Can you show your HA log file so we can see the exact error.
