MQTT setup in Hassio
I try to set up MQTT, Mosquitto broker addon in Hassio.
But I can’t get it to work, can somebody give me a hand.
And I have created following user for the MQTT.
Give MQTT a username and Password DONT make it homeassistand
According to the installation decription, step 3 under Hassio section.
I should configure/add the MQTT Mosquitto broker under the Configuration > Integrations.
But the MQTT is already configure with no devices.
I have not configure it and it give the error as showed above.
Should I still add a user in the add-on config?
Did you create an Access Control List?
As mentioned here: https://www.home-assistant.io/addons/mosquitto/ an explicit ACL definition is now required if you plan to use legacy logins and "anonymous": true.
Don´t forget to add your generated user AND the user homeassistant
I have created an ACL but I thought it should be easier not to use in the beginning.
That why "anonymous": false
Now I get following errors in the logger:
Does anybody know what the problem could be?
I just saw this noteification in Hassio.
But I don’t know what the problem could be?
Please help
