Hi all, I couldnt find this same issue so: Brand new install I have a POE adaptor with Z2m paired to a single door sensor for testing. MQTT is showing me entities but no devices. Is this correct?
Z2M yaml below
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: user
password: password
keepalive: 60
reject_unauthorized: true
version: 4
include_device_information: true
serial:
port: tcp://192.168.1.119:6638
baudrate: 115200
adapter: ember
rtscts: false
disable_led: false
advanced:
transmit_power: 20
frontend:
port: 8099
permit_join: true
devices:
"0xa4c13856df106764":
friendly_name: Patio Door Sensor
homeassistant:
legacy_entity_attributes: false
legacy_triggers: false
ota:
ikea_ota_use_test_url: false
availability:
active:
timeout: 20
passive:
timeout: 540
MQTT yaml
logins:
- username: user
password: password
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
Log
[2024-08-21 19:20:12] info: zh:ember:uart:ash: Out of sequence : RX=0 [2024-08-21 19:20:12] info: zh:ember:uart:ash: ACK timeouts : RX=0 [2024-08-21 19:20:12] info: zh:ember:uart:ash: ======== ASH stopped ======== [2024-08-21 19:20:12] info: zh:ember:ezsp: ======== EZSP stopped ======== [2024-08-21 19:20:12] info: zh:ember: ======== Ember Adapter Stopped ======== [2024-08-21 19:20:13] info: zh:ember: ======== Ember Adapter Starting ======== [2024-08-21 19:20:13] info: zh:ember:ezsp: ======== EZSP starting ======== [2024-08-21 19:20:13] info: zh:ember:uart:ash: ======== ASH Adapter reset ======== [2024-08-21 19:20:13] info: zh:ember:uart:ash: Socket ready [2024-08-21 19:20:13] info: zh:ember:uart:ash: ======== ASH starting ======== [2024-08-21 19:20:14] info: zh:ember:uart:ash: ======== ASH connected ======== [2024-08-21 19:20:14] info: zh:ember:uart:ash: ======== ASH started ======== [2024-08-21 19:20:14] info: zh:ember:ezsp: ======== EZSP started ======== [2024-08-21 19:20:14] info: zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched. [2024-08-21 19:20:14] info: zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.1 [GA]","build":0,"major":7,"minor":4,"patch":1,"special":0,"type":170} [2024-08-21 19:20:14] info: zh:ember: [STACK STATUS] Network up. [2024-08-21 19:20:14] info: zh:ember: [INIT TC] Adapter network matches config. [2024-08-21 19:20:14] info: zh:ember: [CONCENTRATOR] Started source route discovery. 1248ms until next broadcast. [2024-08-21 19:20:25] error: zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=38:"GET_EUI64" Seq=32 Len=13]. [2024-08-21 19:20:25] error: zh:ember: !!! ADAPTER FATAL ERROR reason=ASH_ERROR_TIMEOUTS. !!! [2024-08-21 19:20:25] info: zh:ember: Attempting adapter reset... [2024-08-21 19:20:25] info: zh:ember:uart:ash: ASH COUNTERS since last clear: [2024-08-21 19:20:25] info: zh:ember:uart:ash: Total frames: RX=35, TX=69 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Cancelled : RX=0, TX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: DATA frames : RX=34, TX=33 [2024-08-21 19:20:25] info: zh:ember:uart:ash: DATA bytes : RX=292, TX=335 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Retry frames: RX=0, TX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: ACK frames : RX=0, TX=35 [2024-08-21 19:20:25] info: zh:ember:uart:ash: NAK frames : RX=0, TX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: CRC errors : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Comm errors : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Length < minimum: RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Length > maximum: RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Bad controls : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Bad lengths : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Bad ACK numbers : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Out of buffers : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Retry dupes : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: Out of sequence : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: ACK timeouts : RX=0 [2024-08-21 19:20:25] info: zh:ember:uart:ash: ======== ASH stopped ======== [2024-08-21 19:20:25] info: zh:ember:ezsp: ======== EZSP stopped ======== [2024-08-21 19:20:25] info: zh:ember: ======== Ember Adapter Stopped ======== [2024-08-21 19:20:25] error: z2m: Error while starting zigbee-herdsman [2024-08-21 19:20:25] error: z2m: Failed to start zigbee [2024-08-21 19:20:25] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions [2024-08-21 19:20:25] error: z2m: Exiting... [2024-08-21 19:20:26] error: z2m: Error: ASH_ERROR_TIMEOUTS at Ezsp.ezspVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/ezsp/ezsp.ts:1395:19) at EmberAdapter.emberVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1462:63) at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:750:9) at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1758:24) at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29) at Zigbee.start (/app/lib/zigbee.ts:63:27) at Controller.start (/app/lib/controller.ts:139:27) at start (/app/index.js:154:5) [19:20:26] INFO: Preparing to start... [19:20:26] INFO: Socat not enabled [19:20:27] INFO: Starting Zigbee2MQTT... Starting Zigbee2MQTT without watchdog. [2024-08-21 19:20:28] info: z2m: Logging to console, file (filename: log.log) [2024-08-21 19:20:28] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown) [2024-08-21 19:20:28] info: z2m: Starting zigbee-herdsman (0.55.3) [2024-08-21 19:20:28] info: zh:ember: Using default stack config. [2024-08-21 19:20:28] info: zh:ember: ======== Ember Adapter Starting ======== [2024-08-21 19:20:28] info: zh:ember:ezsp: ======== EZSP starting ======== [2024-08-21 19:20:28] info: zh:ember:uart:ash: ======== ASH Adapter reset ======== [2024-08-21 19:20:28] info: zh:ember:uart:ash: Socket ready [2024-08-21 19:20:28] info: zh:ember:uart:ash: ======== ASH starting ======== [2024-08-21 19:20:29] info: zh:ember:uart:ash: ======== ASH connected ======== [2024-08-21 19:20:29] info: zh:ember:uart:ash: ======== ASH started ======== [2024-08-21 19:20:29] info: zh:ember:ezsp: ======== EZSP started ======== [2024-08-21 19:20:29] info: zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched. [2024-08-21 19:20:29] info: zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.1 [GA]","build":0,"major":7,"minor":4,"patch":1,"special":0,"type":170} [2024-08-21 19:20:30] info: zh:ember: [STACK STATUS] Network up. [2024-08-21 19:20:30] info: zh:ember: [INIT TC] Adapter network matches config. [2024-08-21 19:20:30] info: zh:ember: [CONCENTRATOR] Started source route discovery. 1248ms until next broadcast. [2024-08-21 19:20:30] info: z2m: zigbee-herdsman started (resumed) [2024-08-21 19:20:30] info: z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":1,"revision":"7.4.1 [GA]","special":0,"type":170},"type":"EmberZNet"}' [2024-08-21 19:20:30] info: z2m: Set transmit power to '20' [2024-08-21 19:20:30] info: z2m: Currently 1 devices are joined: [2024-08-21 19:20:30] info: z2m: Patio Door Sensor (0xa4c13856df106764): MC500A - Tuya Door sensor (EndDevice) [2024-08-21 19:20:30] warning: z2m:
permit_joinset to
truein configuration.yaml. [2024-08-21 19:20:30] warning: z2m: Allowing new devices to join. [2024-08-21 19:20:30] warning: z2m: Set
permit_jointo
false once you joined all devices. [2024-08-21 19:20:30] info: z2m: Zigbee: allowing new devices to join. [2024-08-21 19:20:30] info: zh:ember: [STACK STATUS] Network opened. [2024-08-21 19:20:30] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883 [2024-08-21 19:20:30] info: z2m: Connected to MQTT server [2024-08-21 19:20:30] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online' [2024-08-21 19:20:30] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Patio Door Sensor/availability', payload 'online' [2024-08-21 19:20:30] info: z2m: Started frontend on port 8099 [2024-08-21 19:20:30] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":1,"revision":"7.4.1 [GA]","special":0,"type":170},"type":"EmberZNet"},"log_level":"info","network":{"channel":11,"extendedPanID":15987178197214945000,"panID":6754},"permit_join":true,"version":"1.39.1"}' [2024-08-21 19:20:30] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online' [2024-08-21 19:20:30] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Patio Door Sensor', payload '{"battery":100,"battery_low":false,"contact":true,"device":{"applicationVersion":70,"dateCode":"","friendlyName":"Patio Door Sensor","hardwareVersion":1,"ieeeAddr":"0xa4c13856df106764","manufacturerID":4417,"manufacturerName":"_TZ3000_2mbfxlzr","model":"MC500A","networkAddress":22702,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"linkquality":156,"tamper":false,"voltage":3000}' [2024-08-21 19:20:30] info: z2m: Zigbee2MQTT started! [2024-08-21 19:20:35] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x84b4dbfffebc5c45/connection_state/config', payload '{"device":{"hw_version":"EmberZNet 7.4.1 [GA]","identifiers":["zigbee2mqtt_bridge_0x84b4dbfffebc5c45"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.39.1"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.39.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x84b4dbfffebc5c45_connection_state_zigbee2mqtt","value_template":"{{ value }}"}' [2024-08-21 19:21:16] info: z2m: Starting network scan (includeRoutes 'false') [2024-08-21 19:21:17] info: z2m: Network scan finished [2024-08-21 19:21:17] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[{"depth":1,"linkquality":0,"lqi":0,"relationship":1,"routes":[],"source":{"ieeeAddr":"0xa4c13856df106764","networkAddress":22702},"sourceIeeeAddr":"0xa4c13856df106764","sourceNwkAddr":22702,"target":{"ieeeAddr":"0x84b4dbfffebc5c45","networkAddress":0},"targetIeeeAddr":"0x84b4dbfffebc5c45"}],"nodes":[{"definition":null,"failed":[],"friendlyName":"Coordinator","ieeeAddr":"0x84b4dbfffebc5c45","lastSeen":null,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"Door sensor","model":"MC500A","supports":"contact, battery, voltage, battery_low, linkquality","vendor":"Tuya"},"friendlyName":"Patio Door Sensor","ieeeAddr":"0xa4c13856df106764","lastSeen":1724230376847,"manufacturerName":"_TZ3000_2mbfxlzr","modelID":"TS0203","networkAddress":22702,"type":"EndDevice"}]}},"status":"ok","transaction":"chmve-1"}'
