I am having trouble with creating a simple MQTT slider to turn on and off a switch via MQTT. The switch is controlled via MQTT and is a JR-ZDS01. I have created the below config in configuration.yml however I can only only see it as two controllable icons not a slider. The icons work fine but want a slider like my other buttons I have for my Tasmotas.
I have so far worked out that it cant actually see the state of the switch.
switch:
- name: 'Office Light'
unique_id: 'officelight'
state_topic: 'zigbee2mqtt/switch/office'
state_on: '{"state": "ON"}'
state_off: '{"state": "OFF"}'
command_topic: 'zigbee2mqtt/switch/office/set'
payload_on: '{"state": "ON"}'
payload_off: '{"state": "OFF"}'
retain: true
Messages from zigbee2mqtt appear like follows:
Client (null) received PUBLISH (d0, q0, r0, m0, 'zigbee2mqtt/switch/office', ... (85 bytes))
{"linkquality":54,"power_on_behavior":"previous","state":"ON","switch_type":"toggle"}
