I continuously get the below errors
1583483125: Socket error on client <unknown>, disconnecting.
1583483140: New connection from 192.168.1.4 on port 1883.
1583483140: Socket error on client <unknown>, disconnecting.
1583483155: New connection from 192.168.1.4 on port 1883.
1583483155: Socket error on client <unknown>, disconnecting.
1583483170: New connection from 192.168.1.4 on port 1883.
1583483170: Socket error on client <unknown>, disconnecting.
That ip is my haas installation.
All MQTT devices are no problem?
With frequent disconnections it is useful to check whether you have used the same client name on different devices, eg in your HASSIO client and in another device.
I restarted the add-on and followed this in the log.
Initially Haas makes a connection and the id is random, I do not think that is the issue.
Anyone got an idea as to why it keeps disconnecting?
1583738597: New client connected from 192.168.1.4 as auto-2D1982FE-4A07-3ACE-8DC7-6B92D7031053 (p2, c1, k60, u'mqttuser').
1583738606: New connection from 192.168.1.4 on port 1883.
1583738606: Socket error on client <unknown>, disconnecting.
1583738621: New connection from 192.168.1.4 on port 1883.
1583738621: Socket error on client <unknown>, disconnecting.
1583738636: New connection from 192.168.1.4 on port 1883.
1583738636: Socket error on client <unknown>, disconnecting.
On my side this was bad cofiguration that does the problems with users and broken MQTT.
If anybody uses auth_providers , must be added -type: homeassistant .
