Setup:
Home Assistant 0.76.2
Mosquitto broker 2.0 (mosquitto version 1.4.15)
Sonoff 4ch Pro with Tasmota 6.2.1
Config:
S6 Sonoff switch: pos. 1
K5 Sonoff switches: pos. 1 for every channel
mqtt:
broker: 192.168.1.149
port: 1883
client_id: home-assistant
keepalive: 60
username: user
password: pass
protocol: 3.1
birth_message:
topic: "tele/home/LWT"
payload: "Online"
qos: 2
retain: true
will_message:
payload: "Offline"
qos: 2
retain: true
light:
- alias: Living Room
platform: mqtt
state_topic: "stat/home/light/POWER1"
command_topic: "cmnd/home/light/POWER1"
availability_topic: "tele/home/LWT"
qos: 2
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
- alias: Living Room 2nd light
platform: mqtt
name: "Living Room 2nd light"
state_topic: "stat/home/light/POWER2"
command_topic: "cmnd/home/light/POWER2"
qos: 2
payload_on: "ON"
payload_off: "OFF"
retain: false
- alias: Hallway light
platform: mqtt
state_topic: "stat/home/light/POWER3"
command_topic: "cmnd/home/light/POWER3"
qos: 2
payload_on: "ON"
payload_off: "OFF"
retain: false
- alias: Bathroom light
platform: mqtt
state_topic: "stat/home/light/POWER4"
command_topic: "cmnd/home/light/POWER4"
qos: 2
payload_on: "ON"
payload_off: "OFF"
retain: false
Issue description:
Every time I restart Mosquitto broker in Hassio or reset Sonoff module power - 1st channel enables regardless module config.
I bought some Sonoff modules and test them before overhaul in the apartment.
According to my plan, the relay must save its position after a power loss but this channel does not work on this logic - no matter how I turned it off, with a physical button or via web/mqtt, it still turns on after every reboot.
Some times ago I tried to use retain in hassio config for these relays but then disable them. I read I should try to remove retain messages via -r -n for the topics but it doesn’t help to solve the issue.
Here is the log from Tasmota web interface after reboot:
00:00:00 Project sonoff Sonoff (Topic light, Fallback sonoff_4ch_pro_1, GroupTopic sonoffs) Version 6.2.1-2_3_0
00:00:00 WIF: Connecting to AP1 Panch_2.4 in mode 11N as light-8131...
00:00:04 WIF: Connected
00:00:04 DNS: Initialized
00:00:04 HTP: Web server active on light-8131.local with IP address 192.168.1.105
00:00:04 MQT: Attempting connection...
00:00:04 MQT: Connected
00:00:04 MQT: tele/home/light/LWT = Online (retained)
00:00:04 MQT: cmnd/home/light/POWER =
00:00:04 MQT: stat/home/light/RESULT = {"POWER1":"ON"}
00:00:04 MQT: stat/home/light/POWER1 = ON
00:00:04 MQT: tele/home/light/INFO1 = {"Module":"Sonoff 4CH Pro","Version":"6.2.1","FallbackTopic":"sonoff_4ch_pro_1","GroupTopic":"sonoffs"}
00:00:04 MQT: tele/home/light/INFO2 = {"WebServerMode":"Admin","Hostname":"light-8131","IPAddress":"192.168.1.105"}
00:00:04 MQT: tele/home/light/INFO3 = {"RestartReason":"Power on"}
00:00:05 MQT: stat/home/light/RESULT = {"POWER1":"ON"}
00:00:05 MQT: stat/home/light/POWER1 = ON
00:00:05 MQT: stat/home/light/RESULT = {"POWER2":"OFF"}
00:00:05 MQT: stat/home/light/POWER2 = OFF
00:00:05 MQT: stat/home/light/RESULT = {"POWER3":"OFF"}
00:00:05 MQT: stat/home/light/POWER3 = OFF
00:00:05 MQT: stat/home/light/RESULT = {"POWER4":"OFF"}
00:00:05 MQT: stat/home/light/POWER4 = OFF
00:00:05 MQT: homeassistant/light/light_1/config = (retained)
00:00:05 MQT: homeassistant/switch/light_1/config = {"name":"Sonoff","command_topic":"cmnd/home/light/POWER1","state_topic":"stat/home/light/RESULT","value_template":"{{value_json.POWER1}}","payload_off":"OFF","payload_on":"ON","availability_topic":"tele/home/light/LWT","payload_available":"Online","payload_not_available":"Offline"} (retained)
00:00:05 MQT: homeassistant/light/light_2/config = (retained)
00:00:05 MQT: homeassistant/switch/light_2/config = {"name":"Sonoff2","command_topic":"cmnd/home/light/POWER2","state_topic":"stat/home/light/RESULT","value_template":"{{value_json.POWER2}}","payload_off":"OFF","payload_on":"ON","availability_topic":"tele/home/light/LWT","payload_available":"Online","payload_not_available":"Offline"} (retained)
00:00:05 MQT: homeassistant/light/light_3/config = (retained)
00:00:05 MQT: homeassistant/switch/light_3/config = {"name":"Sonoff3","command_topic":"cmnd/home/light/POWER3","state_topic":"stat/home/light/RESULT","value_template":"{{value_json.POWER3}}","payload_off":"OFF","payload_on":"ON","availability_topic":"tele/home/light/LWT","payload_available":"Online","payload_not_available":"Offline"} (retained)
00:00:05 MQT: homeassistant/light/light_4/config = (retained)
00:00:05 MQT: homeassistant/switch/light_4/config = {"name":"Sonoff4","command_topic":"cmnd/home/light/POWER4","state_topic":"stat/home/light/RESULT","value_template":"{{value_json.POWER4}}","payload_off":"OFF","payload_on":"ON","availability_topic":"tele/home/light/LWT","payload_available":"Online","payload_not_available":"Offline"} (retained)
00:00:05 MQT: homeassistant/light/light_5/config = (retained)
00:00:05 MQT: homeassistant/switch/light_5/config = (retained)
00:00:05 MQT: homeassistant/light/light_6/config = (retained)
00:00:05 MQT: homeassistant/switch/light_6/config = (retained)
00:00:05 MQT: homeassistant/light/light_7/config = (retained)
00:00:05 MQT: homeassistant/switch/light_7/config = (retained)
00:00:05 MQT: homeassistant/light/light_8/config = (retained)
00:00:05 MQT: homeassistant/switch/light_8/config = (retained)
23:15:38 MQT: tele/home/light/STATE = {"Time":"2018-09-11T23:15:38","Uptime":"0T00:00:13","Vcc":3.222,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Panch_2.4","RSSI":68,"APMac":"F4:F2:6D:AE:E2:45"}}
If I connect to broker via mqttspy and subscript to “#” topic it always shows cmnd topic for this relay with “ON” value even if it’s OFF and does not show such topics for other relays:
Also I found some info about deleting mosquitto.db but here is no such file or directory if I connect to my RPi with hassio via ssh with root user (looks like I should have permission connect to docker app with this module).
Thank you for any help!
