MQTT Sonoff RF Bridge - Send Signal
Hey everyone, yet another RF Bridge topic :slight_smile:
I have this RF blind that opens/stops/closes via RF Signals in remote control with the codes below.
I could not find the proper way to add this to home assistant using mqqt topics. I use broadlink scripts but would really like to try it with the RF Bridge and compare which one is better.
Thoughts? thanks
Pause:
“sgAQAQABcBkbGhsaTxoaGhsaTxpPGk8aGhobGhsZTxsaGk8aTxpPGhsZGxoaGxoaGxpPGk8aTxobggABcBobGhoaTxobGhobThpPGlAZGxobGhoaTxobGVAaTxpPGhoaGxoaGhsaGhpQGU8aTxobgwABcBobGhoaTxobGRsaTxpPGk8aGxoaGhsaTxoaGk8aTxpPGhsaGxoaGhsZGxpPGk8aTxobgwABcBkbGhsaTxobGRsaTxpPGk8aGhobGhoaTxobGk8aTxpPGhobGhobGhoaGxpPGk8aTxoagwABcBobGhoaUBkbGhoaTxpPGk8aGxobGRsaTxobGU8aUBlPGxoaGxoaGhobGhpPGk8aTxoEAAXcAAAAAAAAAAA=”
Up:
sgCoABwZGxpPGhoaGxpPGk8aTxobGRsaGxpPGhoaTxpPGk8aGxoaGhsaGhobGk8aGhpQGRuDAAFwGhsZGxpPGhsZGxpPGk8aTxobGhoaGxpPGhoaTxpPGk8aGxoaGhsaGhobGk8aGhtOGhuDAAFwGhobGhpPGhoaGxpPGk8aTxobGhoaGxpPGhoaTxpPGk8bGhoaGhsaGxkbGk8aGhtPGhqDAAFwGhsZGwAF3A==
Down:
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
These are definitely not codes for a sonoff rf bridge.
When you issue these commands from your remote control, do you see the RFBridge issuing MQTT payloads directly after? If not, the blinds may not be on 433MHz. That’s the frequency that the RFBridge operates on.
Those were the codes converted so I could use my broadlink pro
