at the moment I am a bit clueless as I am unable to use a Split method in the MQTT configuration .
I receive a string from a sensor
- name: "AHT25_5_status"
state_topic: "AHT25-5/version"
This results in for example “aht25MQTT.ino, 192.168.11.66, Huber1, -80dbm,” and I can easily extract the last component “-80dbm” in ->developer tools → template with
{{ states('sensor.aht25_5_status').split(',')[3]}}
But if I try the same within mqtt.yaml with
- name: "AHT25_5_RSSI"
value_template: >
{{ value.split(',')[3] }}
I always get ‘unknown’ as result for AHT25_5_RSSI
I can, however, use successfully
- name: "AHT25_5_SSID"
value_template: >
{{ value.split(',')[2] }}
Any idea why?
Uli
