Hi all,
I am struggling with splitting up my mqtt configuration. Basically everything in the integration folder is included via the following command from the configuartion.yaml. And this works for other imtegreations smoothly.
packages: !include_dir_named integrations
mqtt:
sensors: !include_dir_merge_list ../entities/mqtt/sensors
bindary_sensors: !include_dir_merge_list ../entities/mqtt/bindary_sensors
switches: !include_dir_merge_list ../entities/mqtt/switches
under …/entities/mqtt/sensors I have to devided between my differnt sensor-typs, enocean and 1-wire. Therefore I have created a folder for “1-wire” and “enocean” I the foder 1-wire there are the different sensor files
Example DS2438
- unique_id: DS2438_temp
name: DS2438 Temperatur
state_topic: "fhem/GH.in.1W.DS2438/temperature"
unit_of_measurement: "°C"
icon: mdi:thermometer
value_template: '{{ value | round(1) }}'
expire_after: 4000
availability_topic: "fhem/connection/status"
payload_available: "connected"
payload_not_available: "disconnected"
but there is a bug in the structure and I do not understand where it is.
The folder structure under “…/entities/mqtt/switches” has to be merged recursively .
Can someone help me to get this solved for the example sensors? after that I can transfer this structure to the switches and bindary_sensors as well!
Thanks for dupport,
Spartacus.
