MQTT state unknow,. How can this be configured?
Hello all,
I do have a source system where I would like to get data from.
HA and MQTT is configured.
Using MQTT Explorer I am able to browse:
Within HA I can browse through the Mosquito browser:
But all the values of e.g. sensors are unknown.
20241211_HA_03
Than I tried to configure these sensors in the configuration.yaml e.g.
But browsing through these in the development tools they are also unknown.
What am I doing the wrong? Is this the wrong syntax?
Thanks in advance!
Tom
I don’t see that state topic in the MQTT Explorer screenshot. Are you sure it’s right?
Please post code as formatted text where possible please, such as your sensor config:
mqtt:
    - name: ...
mqtt:
    - name: "SPA Deluxe Wassertemperatur"
      state_topic: "spanet/b48a0a6f29e4/water/temperature/state/"
      unique_id: "spanet_water_temperature_b48a0a6f29e4"
      device_class: "temperature"
      unit_of_measurement: "°C"
      icon: "mdi:thermometer-water"
“name”: “Spanet Water Temperature”,
“state_topic”: “spanet/b48a0a6f29e4/water/temperature/state/”,
“state_class”: “measurement”,
“device_class”: “temperature”,
“unit_of_measurement”: “°C”,
“icon”: “mdi:thermometer-water”,
“unique_id”: “spanet_water_temperature_b48a0a6f29e4”,
“device”: {
“identifiers”: [
“spanet_b48a0a6f29e4”
“name”: “SmartLink - b48a0a6f29e4”,
“model”: “V3”,
“manufacturer”: “Spanet”
“origin”: {
“name”: “Spanet”,
“sw_version”: “1.17”,
“support_url”: “https://spanet.com.au/”
“qos”: 0,
“optimistic”: false
$SYS/broker/clients
I have the same problem as you with pwsmqttdispatcher
Unknown !
How do you get the following information:
“device”: {
“identifiers”: [
“model”: “V3”,
“origin”: {
“name”: “Spanet”,
When I tried this via terminal :
mosquitto_pub -h 192.168.129.187 -u username -P password -t “pwsmqttdispatcher” -m ‘{“temperature”: 23.0}’
result:
But with configuration.yaml : unknown
mqtt:
    - name: "abc_test_temperature2"
      state_topic: "pwsmqttdispatcher"
      value_template: "{{ value_json['temperature'] | float }}"
      unique_id: "7b259fe2-b64e-11ef-8d03-8f2f5ccfb9ff"
any idea?
:wink:
Hi Thomas1234
It looks like you are trying to find state and control topics in the homeassistant topic, which is used for MQTT discovery MQTT - Home Assistant
Rather have a look for a topic that starts with spanet/[unique_id] for the actual states and control.
If you enable MQTT discovery in Home Assistant, then all the necessary devices are created for you, it should just work.
Cheers
