I am working my way through getting Home Assistant setup for my needs. I finally figured out (I think) how to publish information about certain entities (Garage door state, door lock state) to MQTT using the MQTT Statestream.
I started with HOOBS and had this setup in that instance using the specific myQ plugin in that system. I could transmit a request message and then HOOBS would send out the current state.
I use this information to update a digital dashboard I have setup in my home. The issue is, sometimes the dashboard needs to get rebooted. Is there a way to send an MQTT request to Home Assistant to request an update of current states be resent? If not, I have to wait for the state change on the device to get the MQTT update.
Sorry if this is obvious, but I cannot see how to request this of Home Assistant. Thanks in advance!
