my MQTT switch (servo blinds) doesn’t stay “ON” even payload and state are the same (chcecked by subcsribing to state topic).
Here is part of my comfig-yaml:
Code is working fine but my switch can only open blinds. I have to close them using Developeer Tools–>Services. Only change I made is rename states from opened–>open and closed–>close
Hmm why do you say that the payload_on/off need the quotes removing? I’ve always used quotes on mine and they have always worked fine, also every example in the docs have the quotes. Is there some change I’m not aware of?
