Hi All
New to home assistant, floorplan, mqtt etc.
Sorry if posted in the wrong forum.
I just migrated from Z-wave to zwave2mqtt
I have a switch configured
switch:
- platform: mqtt
name: "Porch Light Switch"
state_topic: "homeassistant/frontdoor/switchporch_light/37/1/0"
command_topic: "homeassistant/frontdoor/switchporch_light/37/1/0/set"
payload_on: "true"
payload_off: "false"
state_on: "true"
state_off: "false"
qos: 0
optimistic: false
retain: true
value_template: '{{ value_json.value }}'
which works and turns on / off the device when triggered.
BUT neither in floorplan nor in lovelace the state is reflected correctly.
As part of troubleshooting, I added the state_on/off and value_template but they did not resolve the issue either.
As example in Lovelace UI, I can trigger the switch and it turns the switch on, but immediately afterwards it reverts the state to off/false although the switch is still on.
I don’t understand / can’t find what I have configured wrong that the state is not recognized correctly.
I am using Mosquito and the state topic is published correctly -->
Topic: homeassistant/switchporch_light/37/1/0
Any help very much appreciated.
