I have an issue with controlling Sonoff Tasmota firmware patch Sonoff POW socket.
The following code based on official example works.
- platform: mqtt
state_topic: "stat/stove-fan/POWER"
command_topic: "cmnd/stove-fan/POWER"
optimistic: false
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
But, if Home Assistant reboots when the switch is ON, the rebooted instance sees it as OFF, because state stat/stove-fan/POWER
is sent only when the state changes.
Because the POW sends telemetry every 5 minutes. I would like use that telemetry as well.
14:47:55 MQT: stat/stove-fan/RESULT = {"POWER":"OFF"}
14:47:55 MQT: stat/stove-fan/POWER = OFF
14:51:24 MQT: tele/stove-fan/STATE = {"Time":"2017-11-12T14:51:24", "Uptime":3, "Vcc":3.116, "POWER":"OFF", "Wifi":{"AP":2, "SSId":"XXX", "RSSI":60, "APMac":"XXX"}}
14:51:24 MQT: tele/stove-fan/ENERGY = {"Time":"2017-11-12T14:51:24", "Total":1.922, "Yesterday":0.228, "Today":0.176, "Period":1, "Power":0, "Factor":0.00, "Voltage":0, "Current":0.000}
And use tele/stove-fan/STATE with POWER information.
I have tried:
- platform: mqtt
state_topic: "tele/stove-fan/STATE"
value_template: '{{value_json.POWER}}'
optimistic: true #has to be true, otherwise it will not switch ON
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
Now, I have changes from HA and in maximum 5 min, the initial state… but I loose immediate notifications when I switch it manually of.
Is there any way how to subscribe to multiple state topics?
