In my use case an MQTT-Switch changes its state like this:
on → undefined → off and
off → undefined → on
Is there a possibility to ignore the “undefined” state?
You could set up a trigger-based template binary sensor that triggers on your switch going on
or off
. With the new template layout:
template:
- trigger:
- platform: state
entity_id: switch.mqtt_switch
to:
- 'on'
- 'off'
binary_sensor:
- name: "Filtered MQTT switch"
state: "{{ states('switch.mqtt_switch') }}"
Thanks a lot! For now I could fix it on the publisher side. But good to know how it would work in HA!
You can also use the MQTT Switch’s value_template to properly handle the three received states. Or its availability_template
(which would allow it to ignore a received value of undefined
