Mqtt switch switching off
Hi, I need some help with a MQTT switch where the state keeps going to off when you click the switch. I have been trying different solutions for weeks now and combing through the forum and Youtube.
So here is what I have set / happens.
* THE PROBLEM
When I toggle the switch for my pool pump (Sonoff POWR2 with Tasmota) the pump turns on and remains on while the switch in homeassistant turns to the off state after a second. If I double click the switch in HA quickly, the pump will turn off. So in short the issue seems to only be with the state of the switch.
* THE CONFIG / INFO
  • I am running the latest version of HASS.IO and I have installed the Mosquitto broker via the addon section.
  • I have configured numerous (light mqtt: - platform: mqtt) switches (The Sonoff TX ones also with Tasmota) and these are working fine or as I would expect.
#          MQTT LIGHTS SECTION                          #
light mqtt:
  - platform: mqtt
    state_topic: "pool_light/stat/POWER"
    command_topic: "pool_light/cmnd/POWER"
    payload_on: "ON"
    payload_off: "OFF"
  • My broker section of the configuration.yaml looks like this:
#          MQTT BROKER SECTION                           #
mqtt:
  broker: 127.0.0.1
  port: 1883
  client_id: 2WLS-HA
  username: mqtt
  password: mypassword
#  discovery: false
#  discovery_prefix: homeassistant
  • And my switch (not working) section of the configuration.yaml looks like this:
#          MQTT SWITCHES SECTION                          #
switch:
  - platform: mqtt
    state_topic: "poolpump/stat/POWER"
    command_topic: "poolpump/cmnd/POWER"
    payload_on: ON
    payload_off: OFF
  • If I listen to the state topic via the Dev Tools/MQTT section, I can see that the broker is communicating to and from the switch. These messages are successfully posted if I use the switches on either the homeassistant or the sonoff web page.
Listen to a topic
Listening to
poolpump/stat/POWER
Message 0 received on poolpump/stat/POWER at 9:46 AM:
ON
QoS: 0 - Retain: true
I have also reset my config and started again but ended at the same result, so I do not believe its a typo. The next step would have been to pull in the power usage for the pool pump and add some automation around that but if I cant even get the switch to work correctly 0_o …
Thank you in advance for any assistance
Have you tried using discovery instead of manual mqtt setup. i think if you type setoption19 1 in the tamota console this enables discovery for HA
You need to put “ON” and “OFF” in quotes. Otherwise YAML regards them as True and False which is not the correct payload.
You are missing quote marks for payload entries.
- platform: mqtt
  state_topic: "stat/sonoff04/POWER"
  command_topic: "cmnd/sonoff04/POWER"
  qos: 1
  payload_on: "ON"
  payload_off: "OFF"
@swiftlyfalling, @Bluey
I really thought I had tested that before and it did not work. Must have mixed it with the changes I made to the state topic and not tested it properly.
Anyhow, adding the quotation marks fixed it. Thanks a lot.
@DemonAngel44
i set up my MQTT automatically by using the “Add Integration” button so i dont seem to have a MQTT section in my configuration.yaml but i am seeing the same behavior as op on my sonoff basic/tasmota switches. is there a way to fix it with my setup or do i need to configure my 4 switches manually to get rid of this behavior (turn on then off)
