Hey y’all,
I’m trying to use a state topic for a mqtt switch to figure out its on/off state. Here’s the switch config I’m using :
- unique_id: Relay
state_topic: "data/fetch"
value_template: "{{ value_json.object.RO1_status}}"
command_topic: "data/down"
payload_on: '{"devEui":"00134", "confirmed":false, "fPort":6, "data":"#1E7"}'
payload_off: '{"devEui":"00134", "confirmed":false, "fPort":6, "data":"#1F7"}'
qos: 0
retain: true
Below is an example of a payload that I receive on my state topic:
"deduplicationId": "abcde",
"time": "2025-01-17 23:22:42",
"deviceInfo": {
"tenantId": "afbfcfde",
"tenantName": "xxxxabcde",
"tags": {}
"confirmed": false,
"data": "01234abcde",
"object": {
"RO2_status": "OFF",
"RO1_status": "ON"
"rxInfo": [
"uplinkId": 0123401234,
"rssi": -65,
"snr": 24,
"channel": 2,
"rfChain": 1,
"metadata": {
"region_config_id": "01234US",
"region_common_name": "1234US"
"crcStatus": "CRC_OK"
"txInfo": {
"frequency": 0123400,
"modulation": {
"lora": {
"bandwidth": 125000,
"spreadingFactor": 8,
"codeRate": "CR_1_2"
The switch shows up as lightning icons. When I turn on the switch, the lighting “on” icon doesn’t turn green - it just stays black. Same thing for when I turn it “off”. I’m not sure it’s parsing the state value correct (ie. RO`1_status)? The on/off payload command does go through though - the appliance turns on/off.
Any suggestions? Also, can I have the toggle icon instead of the lighting ones?
