MQTT switch with a different look
If I create a mqtt switch in configuration.yaml like this:
and I put that switch on the UI, it uses lighting bolts for the on/off touch buttons.
How do we make on that is a slider toggle like this?
Please don’t post pictures of text. Pictures of text that only show half of the configuration are even worse.
Post the full switch configuration and format it correctly as per point 11 here.
