i want to create an mqtt switch which would get the state from a contactsensor.
this is what i have, but i’m not sure what to set for the state topic.
which is provided by a sensor and has this payload
{"battery":86,"contact":true,"linkquality":47,"voltage":2975}
obviously if contact = true, the door is closed, so switch should be OFF
but this doesn’t work, otherwise i won’t be here… any suggestions?
switch:
- platform: mqtt
unique_id: garagedoor_switch
state_topic: "zigbee2mqtt/GarageDeur"
command_topic: "home/garagedoor/switch/set"
payload_on: "OPEN"
payload_off: "CLOSE"
state_off: "contact"
optimistic: false
qos: 0
retain: true
