All my Tasmota that connected via MQTT is now grey out which is not available in my HASS. Wondering if anyone have the same problem. This occurs upon HASS update from 113.3 to 114
What broker are you using?
I filed an issue on github when the beta came out. Maybe you can add your findings there.
hey man @francisp thanks for the info… btw when you said delete entity and resend the discovery messages… could you give an example… hahaha… dont want to screw my current setup… Thanks again
For Tasmotas, you can just enter, in the Tasmota console,
setoption19 0
setoption19 1
ah… yeah I forget about that one… however this will be painfull since I need to di it one by one…
Anyway… Thanks alot broo
I should look it up in the Tasmota documentation, but it can be done by sending mqtt messages to the tasmota group topics (sonoffs for older Tasmota firmwares, tasmotas for newer versions)
Or by using tasui or tasmoadmin
I don’t know if it’s the same problem but for me it’s my mqtt docker who doesn’t work since the update of HA (it’s link ???)
all my mqtt sensor are unavailable tasmota, zigbee2mqtt wait for information
thanks
Can you connect to it using mqtt explorer ?
Hello i think no my Mqtt Docker stop and try to restart always here the log
mqtt
date,stream,content
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: GENERAL_NAME_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_get1_basic: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_bio: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_by_id: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: PEM_read_DHparams: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EC_KEY_new_by_curve_name: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_rbio: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_s_mem: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_load_private_key: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_data_X509_STORE_CTX_idx: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_verify_result: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_alpn_protos: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_write: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_opener: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_ex_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_check_private_key: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_load_builtin_engines: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_servername: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_cert_store: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_PrivateKey: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_free_all: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_info_callback: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_writer: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ERR_get_error: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_load_error_strings: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_connect: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_opener: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: sk_num: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_print_ex: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_index_by_NID: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_check_validity: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_finish: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ASN1_STRING_get0_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EC_KEY_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_resp_count: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_cipher_list: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_PrivateKey_file: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_MD_CTX_new: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_pending: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_set_flags: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ERR_error_string: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BN_bn2bin: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_error_depth: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_ctrl: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_writer: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_load_crl_file: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_get_ext_d2i: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_cert_status_str: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_load_verify_locations: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_ctrl: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_new: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_entry: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_peer_certificate: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_ex_new_index: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_OpenSSL: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_get_digestbyname: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_new: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_accept: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_RESPONSE_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_status_str: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestUpdate: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_closer: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OPENSSL_init_crypto: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ERR_clear_error: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_basic_verify: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_crl_reason_str: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_set_flags: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_shutdown: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OPENSSL_add_all_algorithms_noconf: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BN_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_new: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_ctrl: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_current_cert: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ERR_error_string_n: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestInit_ex: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_read: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_closer: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_new_socket: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_ex_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_single_get0_status: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: d2i_OCSP_RESPONSE: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_library_init: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_destroy_method: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_wbio: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: CONF_modules_unload: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_ex_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_SSL_CTX: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_session_id_context: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_peer_cert_chain: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_get_subject_name: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_reader: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: RAND_bytes: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_resp_get0: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_f_base64: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_default_passwd_cb_userdata: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_default_passwd_cb: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_read: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_ctrl_cmd: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_create_method: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BN_num_bits: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_verify: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_callback_ctrl: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BIO_push: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_ENTRY_get_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_new_index: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_fd: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_certificate_chain_file: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_status: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_reader: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_init: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_add_lookup: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_SSL_CTX: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestFinal_ex: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_want: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSLv23_server_method: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OCSP_BASICRESP_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: sk_value: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_set_default: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_write: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_ex_data: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: EVP_MD_CTX_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: OBJ_sn2nid: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: sk_pop_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: BN_hex2bn: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: TLS_server_method: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_free: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_fd: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_error: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: ASN1_STRING_length: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: TLS_client_method: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: SSL_state: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_LOOKUP_file: symbol not found
2020-08-13 06:55:48,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_text_by_NID: symbol not found
2020-08-13 06:55:48,stdout,Error loading shared library libcrypto.so.46: No such file or directory (needed by /usr/sbin/mosquitto)
2020-08-13 06:55:48,stdout,Error loading shared library libssl.so.48: No such file or directory (needed by /usr/sbin/mosquitto)
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: GENERAL_NAME_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_get1_basic: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_bio: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_by_id: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: PEM_read_DHparams: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EC_KEY_new_by_curve_name: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_rbio: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_s_mem: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_load_private_key: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_data_X509_STORE_CTX_idx: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_verify_result: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_alpn_protos: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_write: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_opener: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_ex_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_check_private_key: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_load_builtin_engines: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_servername: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_cert_store: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_PrivateKey: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_free_all: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_info_callback: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_writer: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ERR_get_error: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_load_error_strings: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_connect: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_opener: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: sk_num: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_print_ex: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_index_by_NID: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_check_validity: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_finish: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ASN1_STRING_get0_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EC_KEY_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_resp_count: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_cipher_list: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_PrivateKey_file: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_MD_CTX_new: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_pending: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_set_flags: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ERR_error_string: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BN_bn2bin: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_error_depth: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_ctrl: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_writer: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_load_crl_file: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_get_ext_d2i: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_cert_status_str: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_load_verify_locations: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_ctrl: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_new: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_entry: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_peer_certificate: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_ex_new_index: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_OpenSSL: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_get_digestbyname: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_new: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_accept: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_RESPONSE_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_status_str: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestUpdate: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_closer: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OPENSSL_init_crypto: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ERR_clear_error: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_basic_verify: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_crl_reason_str: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_set_flags: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_shutdown: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OPENSSL_add_all_algorithms_noconf: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BN_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_new: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_ctrl: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_CTX_get_current_cert: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ERR_error_string_n: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestInit_ex: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_read: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_closer: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_new_socket: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_ex_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_single_get0_status: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: d2i_OCSP_RESPONSE: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_library_init: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_destroy_method: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_wbio: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: CONF_modules_unload: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_ex_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_SSL_CTX: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_session_id_context: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_peer_cert_chain: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_get_subject_name: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_get_reader: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: RAND_bytes: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_resp_get0: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_f_base64: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_default_passwd_cb_userdata: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_default_passwd_cb: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_read: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_ctrl_cmd: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_create_method: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BN_num_bits: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_verify: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_callback_ctrl: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BIO_push: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_ENTRY_get_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_new_index: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_fd: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_use_certificate_chain_file: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_status: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: UI_method_set_reader: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_init: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_STORE_add_lookup: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_SSL_CTX: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_DigestFinal_ex: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_want: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSLv23_server_method: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OCSP_BASICRESP_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: sk_value: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_set_default: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_write: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_get_ex_data: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: EVP_MD_CTX_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: OBJ_sn2nid: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: sk_pop_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: BN_hex2bn: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: TLS_server_method: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_free: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_fd: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_error: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: ASN1_STRING_length: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: TLS_client_method: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: SSL_state: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_LOOKUP_file: symbol not found
2020-08-13 06:55:22,stdout,Error relocating /usr/sbin/mosquitto: X509_NAME_get_text_by_NID: symbol not found
2020-08-13 06:55:22,stdout,Error loading shared library libcrypto.so.46: No such file or directory (needed by /usr/sbin/mosquitto)
2020-08-13 06:55:22,stdout,Error loading shared library libssl.so.48: No such file or directory (needed by /usr/sbin/mosquitto)
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: GENERAL_NAME_free: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: OCSP_response_get1_basic: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: SSL_set_bio: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_by_id: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: PEM_read_DHparams: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: EC_KEY_new_by_curve_name: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_rbio: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: BIO_s_mem: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: ENGINE_load_private_key: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_ex_data_X509_STORE_CTX_idx: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: SSL_get_verify_result: symbol not found
2020-08-13 06:55:09,stdout,Error relocating /usr/sbin/mosquitto: SSL_CTX_set_alpn_protos: symbol not found
Try reinstalling your docker.
Same Problem but i find this line in the log
2020-08-13 07:16:36 stdout Error loading shared library libcrypto.so.46: No such file or directory (needed by /usr/sbin/mosquitto)
2020-08-13 07:16:36 stdout Error loading shared library libssl.so.48: No such file or directory (needed by /usr/sbin/mosquitto)
What docker image are you using, and on what OS ?
image : eclipse-mosquitto
on NAS Synology DS920+ DSM 6.2.3-25426 Update 2
Mine is running from Synology and so far its running OK base on the portainer.
hello Richard and witch image of MQTT docker do you use ?
eclipse-mosquitto
I have delete my MQTT docker with lastest version 1.6.11 and install docker with the version 1.6.10 and this run problem with the last version !!!
Same issue here,
All Grey with update 114
Had to fall back to 113.3
I run MQTT server from a different pi
I had the same issue, I just changed my few tasmota devices to ESPHome. I had been meaning to change them for a while anyway!
