So I’ve got 2 switches, 1 is running on a Sonoff (works perfectly), and the second is running off a Shelly. I flashed both with Tasmota.
When I go directly to the IP address of the non-working shelly switch (called warehouselight in my .yaml file), I can toggle it on and off just fine from the tasmota interface. However in HA, I cannot toggle it (switch moves to on, a few seconds later it moves back to off).
I cannot spot an error, but here is my conf.yaml code for this:
switch:
- platform: mqtt
command_topic: "cmnd/patbedroomlamp/power"
state_topic: "stat/patbedroomlamp/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/warehouselight/power"
state_topic: "stat/warehouselight/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
I have triple checked, the switch is in fact named ‘warehouselight’ inside tasmoto, the same as I setup the bedroom lamp. Since the Shelly works just fine by going directly to it, I assume the issue is with my HA .yaml file. Any idea what might be going on??
Thank you!!
