I’m new here. I like Home Assistent and I’m doing more and more with it. I’m a fan of Tasmota. The only thing is, I want to controll 16 lights at once and also be able to controll them seperatly. Since I’m building them myself I thought I use the PCA9685 which can cotrol 16 PWM outputs. Nice. Then I use a ESP12F to control the PCA9685. This also workts. Only a little different then the normal PWM outputs of the ESP’s.
I searched the web and even this forum. Can’t find anything to control the lights from HA.
In MQTT I can controll it:
cmnd/tasmota_AB9BFB/driver15 status
tele/tasmota_AB9BFB/SENSOR {“Time”:“2021-05-25T15:25:47”,“PCA9685”:{“PWM_FREQ”:1500,“PWM0”:0,“PWM1”:0,“PWM2”:0,“PWM3”:0,“PWM4”:0,“PWM5”:0,“PWM6”:0,“PWM7”:0,“PWM8”:0,“PWM9”:0,“PWM10”:0,“PWM11”:0,“PWM12”:0,“PWM13”:0,“PWM14”:0,“PWM15”:0,“END”:1}}
cmnd/tasmota_AB9BFB/driver15 pwm,0,1000
stat/tasmota_AB9BFB/RESULT {“PCA9685”:{“PIN”:0,“PWM”:1000}}
cmnd/tasmota_AB9BFB/driver15 pwm,pin,OFF
stat/tasmota_AB9BFB/RESULT {“PCA9685”:{“PIN”:0,“PWM”:0}}
cmnd/tasmota_AB9BFB/driver15 pwm,pin,ON
stat/tasmota_AB9BFB/RESULT {“PCA9685”:{“PIN”:0,“PWM”:4096}}
Is there anyone who can help me on an example to create a section in configuration.yaml to control this as light:
In addition, it would be nice if I can manage to remember somewhere the value of the channel when turned off.
Thanks in advance.
Marc
