MQTT temperature and humidity monitoring device
This project uses an ESP8266 and Si7021 sensor to remotely monitor temperature & humidity. Data is published to Home Assistant via MQTT where it can be monitored and used for automations.
Build details: https://www.hackster.io/colinodell/mqtt-temperature-and-humidity-monitor-for-home-assistant-27b8d1
Untitled
That looks good. If you get two running I would love to know your results. I have two devices that I am trying to connect to the mosquitto mqtt broker in hassio and only the last one stays connected… maybe I am missing something.
thanks, terry
