mc74909
(Marc Collignon)
1
I have integrated my SMA solar converter using the instructions given here:Integration with SMA Solar STP 10000TL-20 via SBFspot
I cannot get the sensor to show up as energy source.
I have:
- platform: mqtt
state_topic: "sbfspot_304991214"
name: "Inverter Total Yield"
value_template: "{{ value_json.ETotal }}"
last_reset_value_template: "{{ as_datetime('1970-01-01T00:00:00+00:00') }}"
unit_of_measurement: 'kWh'
icon: mdi:solar-power
state_class: "measurement"
device_class: "energy"
as sensor configuration.
The last_reset_value_template is working. If I put that template as value_template, I get some 2000 weeks ago.
In the Developer tools, I also don’t see the last_reset appear.
state_class: measurement
unit_of_measurement: kWh
friendly_name: Inverter Total Yield
device_class: energy
Any idea what I am overlooking ?
francisp
(Francis)
2
Trhis should work :
- platform: mqtt
last_reset_topic: "sbfspot_304991214"
last_reset_value_template: '1970-01-01T00:00:00+00:00'
You can’t use last_reset_value_template without last_reset_topic
mc74909
(Marc Collignon)
3
Thank you Francis, I would never have come up with the link between the 2. It makes a lot of sense however.
It ended up to be adding the topic but keeping the template. The following is the working one.
- platform: mqtt
francisp
(Francis)
4
The template was not really necessary, mine work hardcoded. But if it works, it works
