Hi!
I am running a script on one of my servers which checks the health of an array and publishes the text output of megacli using mqtt.
I configured an mqtt text sensor in HA to recieve this.
But somehow the entity stays undefined.
The payload:
-- Controller information --
-- ID | H/W Model | RAM | Temp | BBU | Firmware
c0 | LSI MegaRAID SAS 9240-4i | 0MB | N/A | Absent | FW: 20.11.1-0137
-- Array information --
-- ID | Type | Size | Strpsz | Flags | DskCache | Status | OS Path | CacheCade |InProgress
c0u0 | RAID-1 | 930G | 64 KB | RA,WT | Default | Optimal | /dev/sdb | None |None
c0u1 | RAID-1 | 893G | 64 KB | RA,WT | Default | Degraded | /dev/sdc | None |None
-- Disk information --
-- ID | Type | Drive Model | Size | Status | Speed | Temp | Slot ID | LSI ID
c0u0p0 | SSD | 2144FQ450102 SanDisk SDSSDH3 1T00 415020RL | 930.3 Gb | Online, Spun Up | 6.0Gb/s | N/A | [64:0] | 5
c0u0p1 | SSD | 20371D801058 SanDisk SSD PLUS 1000GB UH5100RL | 930.3 Gb | Online, Spun Up | 6.0Gb/s | N/A | [64:3] | 6
c0u1p1 | SSD | HKR02P2BXA960LE10063 SF441121 | 893.1 Gb | Online, Spun Up | 6.0Gb/s | N/A | [64:2] | 7
There is at least one disk/array in a NOT OPTIMAL state.
RAID ERROR - Arrays: OK:1 Bad:1 - Disks: OK:3 Bad:0
mqtt_text.yaml:
text:
- name: megaraid_text
unique_id: megaraid_text
state_topic: maul/state/megaraid_text
command_topic: maul/bla
(command topic is not needed, as the script does not listen, only submit)…
Does anyone know this problem and could give me some hints?
bBest regards and thanks in advance,
Otto
