Mqtt topic wildcard
I have an automation which works for a single switch (tasmota mini). However, I have more switches, each with a different topic, based on the sonoff mini serial number. I would like the automation to run if any of the tasmota switches sends the command matching the template.
Are there some wildcard characters or some other method I can add to the topic line in the trigger to make this work?
Current automation below:
- id: '1640192821228'
  alias: Turn off all lights
  description: ''
  - platform: mqtt
    topic: "stat/tasmota_EA268D/RESULT"
  condition:
  - condition: template
    value_template: "{{ trigger.payload_json['Switch1']['Action'] == 'HOLD'}}"
  - service: light.turn_off
      entity_id: light.little_house_lights
  mode: single
Thanks for you help.
Yes. Refer to the Wildcard section here:
You’ll probably want to use the + wildcard.
    topic: "stat/+/RESULT"
However, if the second level within the topic can represent more devices than just the switches then the condition will need modification.
Many thanks for the tip and the link. The explanation of how the MQTT wildcards work was exactly what I was looking for.
Tested and working.
Is this still current? I’m trying to organise ESpresense devices:
  qos: 0
  retain: false
  topic: "espresense/rooms/+/exclude"
  payload: >-
    node:study node:lounge node:kitchen node:north_study
    node:pantry node:bedroom node:kids_bedroom node:bathroom
But I get the error : Wildcards cannot be used in topic names for dictionary value @ data[‘topic’]. Got None
AFAIK, it works for listening, not for publishing.
