So I am almost done setting up my own house. Touch sensors, and voice control via Alexa all work perfect. However I have an issue with two relays when controlling them via Hassio web interface. Stairs and Backyard seem to be attached. If I turn either of them on, both turn on, if I turn either of them off, both turn off.
I went ahead and uninstalled mqtt, re started, and re installed mqtt again, and did a new mqtt integration. I am gong the auto discovery route. After the new integration I have the same issue with the same two relays.
At the moment I mostly use Alexa voice commands and the physical sensors to control the lights, so not a huge deal right now, but eventually I do want to get into automation so that is when I will have issues with it.
Any ideas of what it can be? How I can trouble shoot?
I did try qith mqtt explorer, but can’t say I understand much of what is going on. However I think I know where the problem is, just not sure how to fix it.
There is a tree, on top my mqtt server IP,
then lists out “sonoff” “MannyBedroom”, “Mirswtich”, “MiriamSwitch”.
When I turn either stairs or backyard with Alexa or with web interface, I see the “sonoff” area blink. MannyBedroom is correct, but for example “mirswitch” was friendly name i used in previous build, have changed friendly name to “bathroom”, but still lists old name. Again when I trigger bathroom lights I can see “mirswitch” blink. Finally “MiriamSwitch” is tha name of a swtich no longer in the network.
How can I change those names? I did a quick look throughout tasmota options, and didn’t find anything. Figured deleting mqtt and re installing it would clear old info.
