New to this HA lark, and have just setup a dedicated thin i386 HAOS install- trying to get the MQTT broker up and running ready for when dongle arrives. so far the auto intergration fails so have tried it manually but still cannot manage to connect to the broker
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[21:04:47] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[21:04:48] INFO: Starting NGINX for authentication handling…
s6-rc: info: service legacy-services successfully started
[21:04:48] INFO: Starting mosquitto MQTT broker…
2024-03-18 21:04:48: Warning: Mosquitto should not be run as root/administrator.
2024-03-18 21:04:48: mosquitto version 2.0.18 starting
2024-03-18 21:04:48: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-03-18 21:04:48: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-03-18 21:04:48: ├── Username/password checking enabled.
2024-03-18 21:04:48: ├── TLS-PSK checking enabled.
2024-03-18 21:04:48: └── Extended authentication not enabled.
2024-03-18 21:04:48: Opening ipv4 listen socket on port 1883.
2024-03-18 21:04:48: Opening ipv6 listen socket on port 1883.
2024-03-18 21:04:48: Opening websockets listen socket on port 1884.
2024-03-18 21:04:48: mosquitto version 2.0.18 running
2024-03-18 21:04:49: New connection from 127.0.0.1:46574 on port 1883.
2024-03-18 21:04:49: Client disconnected due to protocol error.
[21:04:49] INFO: Successfully send discovery information to Home Assistant.
[21:04:50] INFO: Successfully send service information to the Supervisor.
2024-03-18 21:07:40: New connection from 172.30.32.2:46478 on port 1883.
2024-03-18 21:07:40: Client closed its connection.
2024-03-18 21:07:59: New connection from 192.168.0.32:36819 on port 1883.
error: received null username or password for unpwd check
2024-03-18 21:07:59: Client 3lQcgEvLY6p1EKAZmSBMBC disconnected, not authorised.
2024-03-18 21:09:09: New connection from 192.168.0.32:39043 on port 1883.
2024-03-18 21:09:09: Client 0oGMBkkYe4h7ZJqJjgGEzM disconnected, not authorised.
2024-03-18 21:09:40: New connection from 172.30.32.2:44558 on port 1883.
2024-03-18 21:09:40: Client closed its connection.
2024-03-18 21:11:40: New connection from 172.30.32.2:51346 on port 1883.
2024-03-18 21:11:40: Client closed its connection.
2024-03-18 21:13:40: New connection from 172.30.32.2:39636 on port 1883.
2024-03-18 21:13:40: Client closed its connection.
2024-03-18 21:14:04: New connection from 192.168.0.32:53071 on port 1883.
2024-03-18 21:14:04: Client 4I7Y75JEtg5fMFSgnASnHS disconnected, not authorised.
any ideas, other that reverting to a fresh install and just trying again?
