DaveTiff
(Dave T)
December 23, 2017, 5:39pm
1
Hi
Using HSS.io and used the MQTT add on.
Getting this error message
Error: Unable to open include_dir ‘/share/mosquitto’.
Error found at /etc/mosquitto.conf:19.
Error: Unable to open configuration file.
How do I navigate to these files, or whats the solution
Re Dave
Set active to false under the customize section of the addon’s options.
Just had the same problem. I’m on a self installed hassio amd64
I added a mosquitto directory to hassio/share/mosquitto and it got me past the error.
DaveTiff
(Dave T)
December 24, 2017, 4:28pm
4
Hi
“active to false” did it, thanks for the reply
I installed WinSCP, so can now see all files & folders.
Regards, Dave
jatgm1
(jatgm1)
August 30, 2022, 10:12pm
6
So what does active mean in this context? Just wondering why setting it to true is a problem. I don’t see anything in documentation tab.
customize.active :
If set to true
additional configuration files will be read, see the next option.
I.e. if it’s true then the files/folders you list in the next two options have to actually exist or you get errors like what is shown above. If it’s false it doesn’t matter what’s in those options.
