I have installed HA from the “Raspberry Pi All-In-One Installer” which other than taking a while, works beautifully! While testing Owntracks with cloudmqtt I worked out what I was looking to do with the application and am now ready to use the local MQTT with Owntracks. The issue I am having is that the installed MQTT looks to use the default PI credentials (not super secure when you want to open it to the world)… is there a way to change it? and if so where? any help would be greatly appreciated.
Thanks @ih8gates - i saw that but was unsure of what user that pertains too… is that the user specified in the YAML file or is that a client connection credentials or is that the same thing?
So the credentials in YAML file is a db connection credential for HA to talk to MQTT? and the the pwfile is actual device/user credential for access to read/write to the system? Is that the way it is setup?
Hi, im total beginner.
I try to setup MQTT user, so that this user dont have access to Hass WEB interface, but it will be used only for MQTT acl.
Useing HassOS v 3.8, so i cant execute command for generating password file:
from manual: Create a new user for MQTT via the Configuration -> Users (manage users) . Note: This name cannot be homeassistant or addon , those are reserved usernames.
But if i create this user, it can log in to web UI, so i dont want expose this user to Hass login page. Therefore i decided to create some password file (acl file only stores users names, not passwords).
But in Hassos i cant execute command for creating this file.
ok, finded this: set the path to a password file. If defined, the contents of the file are used to control client access to the broker. The file can be created using the mosquitto_passwd utility. If mosquitto is compiled without TLS support (it is recommended that TLS support is included), then the password file should be a text file with each line in the format “username:password”, where the colon and password are optional but recommended.
