I’m a bit confused too. I’m using the default configuration for the add-in, and I seem to be getting an error that I do not understand.
I’m using an M5Stamp Pico as teh ESP32 device.
Configuration:
![image](https://community-assets.home-assistant.io/original/4X/6/4/3/64374ac2a903146de55fe448e4c6e6050b3e50fd.png)
Log file:
Suspecting that it might be that I had not defined an MQTT user, I went and created one:
And then modified the Mosquitto configuration to add the username and password.
The log appears to be fine after the restart, but I get the same error message.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[13:52:39] INFO: Setting up user mosquitto
[13:52:39] INFO: Certificates found: SSL is available
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[13:52:39] INFO: Starting NGINX for authentication handling...
[13:52:39] INFO: Starting mosquitto MQTT broker...
1651236759: mosquitto version 1.6.12 starting
1651236759: |-- *** auth-plug: startup
[13:52:39] INFO: Successfully send discovery information to Home Assistant.
[13:52:40] INFO: Successfully send service information to the Supervisor.
1651236759: Config loaded from /etc/mosquitto/mosquitto.conf.
1651236759: Loading plugin: /usr/share/mosquitto/auth-plug.so
1651236759: ├── Username/password checking enabled.
1651236759: ├── TLS-PSK checking enabled.
1651236759: └── Extended authentication not enabled.
1651236759: Opening ipv4 listen socket on port 1883.
1651236759: Opening ipv6 listen socket on port 1883.
1651236759: Opening websockets listen socket on port 1884.
1651236759: Opening ipv4 listen socket on port 8883.
1651236759: Opening ipv6 listen socket on port 8883.
1651236759: Opening websockets listen socket on port 8884.
1651236759: Warning: Mosquitto should not be run as root/administrator.
1651236759: mosquitto version 1.6.12 running
1651236759: New connection from 127.0.0.1 on port 1883.
1651236759: Socket error on client <unknown>, disconnecting.
1651236762: New connection from 192.xxx.xxx.xxx on port 1883.
1651236762: Socket error on client <unknown>, disconnecting.
On the ESPresence website I get this log from the Firmware page after restarting the M5Stamp Pico device.
Connecting to WiFi SSID 'Miles-Home'.....................192.xxx.xxx.xxx
Firmware: esp32
Version: v2.1.1
IP address: 192.xxx.xxx.xxx
DNS address: 192.xxx.xxx.xxx
Hostname: espresense-entrance
Room: entrance
MQTT server: 192.xxx.xxx.xxx:1883
Max Distance: 16.00
PIR Sensor: disabled
Radar Sensor: disabled
Query:
Include:
Exclude:
Known Macs:
Count Ids:
1 New | MAC: d2xxxxxxxx6c, ID: sonos:d2d2d3bf686c
1 New | MAC: 56xxxxxxxx91, ID: sd:0xfe9f
[E][main.cpp:291] onMqttDisconnect(): Disconnected from MQTT; reason 5
1 New | MAC: 13xxxxxxxxc3, ID: md:0006:27
1 New | MAC: 52xxxxxxxx2a, ID: exp:20 4f2626fd04f3c35773588a7111350de3af5626e8
1 New | MAC: 01xxxxxxxx40, ID: msft:cdp:0902 473cd7f3fdc99da75c3d7ebaa1f5e70a0d4f9aab
1 New | MAC: 4cxxxxxxxx4f, ID: 4cxxxxxxxx4f
1 Close | MAC: 7cxxxxxxxxbb, ID: 7cxxxxxxxxbb (0.00m) -39dBm
1 New | MAC: 7cxxxxxxxxbb, ID: 7cxxxxxxxxxbb
1 New | MAC: 73xxxxxxxx6f, ID: sd:0xfe9f
1 New | MAC: 6axxxxxxxx59, ID: sd:0xfe9f
1 Close | MAC: 01xxxxxxxx40, ID: msft:cdp:0902 (0.15m) -39dBm
1 New | MAC: e4xxxxxxxx0e, ID: tile:e4xxxxxxxx0e
1 Close | MAC: e3e1323cc0ab, ID: tile:e3xxxxxxxxab (0.00m) -37dBm
1 New | MAC: e3e1323cc0ab, ID: tile:e3xxxxxxxxab
1 New | MAC: 7cxxxxxxxx11, ID: 7cxxxxxxxx11
0 Reconnect timer
0 Reconnecting to MQTT...
0 Reconnect timer
I can see that there is an error in main.cpp:291
with a reason code 5
Is this a bug or an error on my side?
