I am setting up a home assistant sensor to monitor a solar charge controller and have had some luck with most of the parameters but I am having issues with trying to truncate the first 8-bits in a 16-bit integer value.
bits 0:7 are the controller temp and 8:15 are the battery temp.
The controller temp is UNKNOWN in the dashboard. I have it working for voltage and charge current but can’t quite figure out how to truncate this value.
I’ve also tried value_template: "{{ value_json.TEMPERATURE[0:8] | int(base=16) }}", but it was still UNKNOWN.
I am actually trying to truncate the last 8-bits and keep the first 8.
JSON example: {"TEMPERATURE":6144}
Here the decimal value 6144 is 0001 1000 0000 0000 in binary. If we truncate the last 8-bits we are left with 0001 1000 which is decimal 24 representing 24 °C.
Before, I was editing my YAML, running the config check script, then restarting HA to see if it worked.
I appreciate your help, its my first time joining the forum but I’ve been probably a year-long lurker while setting up HA. Creating sensors and the value_template is probably the most challenging part I’ve come across.
Once you become accustomed to using the Template Editor to test-drive your templates, you’ll smile a bittersweet smile when you reminisce about the old days when you went through the rigmarole of Config Check and restart!
