I have a WH24P weather station from the Chinese company MISOL(http://aliexpress.com/item/32976403129.html). It’s an impressive weather station. This is the struct I’m using in Arduino to show you the options:
struct WH24PData
bool Valid = false;
bool LowBattery;
unsigned int WindDirection;
float WindSpeed;
float Temperature;
uint8_t Humidity;
float GustSpeed;
unsigned int TotalRainfall;
unsigned int UV;
uint8_t UVIndex;
float Light;
This device doesn’t allow receiving any settings or requests. It communicates by sending a RS485 signal that is translated to a normal UART by a RS485-TTL converter. The device sends 21 bytes each 16 seconds. I’m using a NodeMCU v3 for this project. I have installed MQTT explorer onto my computer and see the communication of other devices (Tasmota and my Arduino MQTT example). I use a PubSubClient for MQTT in Arduino. Everything is going well, but how can I integrate this weather station in home assistant. I’m new in home assistant and MQTT.
I could emulate a MQTT Tasmota device, but I see this only as a last option. I prefer to make my own MQTT device made compatible with home assistant. Can I use a MQTT weather standard for this device? Are there standard topics? If not, how can I process custom topics in home assistant?
Maybe another option is to make it compatible with weather underground and let home assistant get data from the weather underground server for a specific node(my node)? I don’t know if weather underground is happy with updates each 16 seconds?
Any help is welcome. Please tell me which topics to publish and how it works best in home assistant…
Thanks in advance for your help.
Kind regards,
Erik
